Är det någon som har det mista intresse i att äga ett exemplar av denna så är det läge att beställa (kanske försent..)?
Den kommer att tryckas i 500 ex som var och ett är handsignerat av "alla" som var något på grupp B-tiden och numrerade.
Now that we have a prototype of the book, we can tell you some definite statistics of which probably the most impressive is that it weighs just over twelve kilograms - twenty-six and half pounds. You may need to test your shelf or coffee table to be sure it can take the weight. The two volumes fit into a specially designed slipcase of which the external dimensions are 36cm x 36cm x 14.5cm (14.2 inches x 14.2 inches x 5.7 inches). There are over 1,000 pages of extra thick paper and the covers are made from leather and linen. In addition, each book carries an engraved metal plate bearing your individual customer number. Inside - and these numbers are conservative - there are more than 2,500 photographs and 250 original documents while, at the last count, there were getting on for 200,000 words.
http://www.thegroupbbook.com/
