Ramlade då in på en rätt kul annons som sålde en sorts digitalvariant av mätartavla. Dock inte min stil av mätartavla som jag skulle vilja ha imin GT men ändå.
Länk till annonsen: http://cgi.ebay.co.uk/Audi-Typ-81-85-Qu ... 286.c0.m14
Description of article: A complete combination instrument (Tacho) for: AUDI type 81/85 also Quattro also similar to Tacho This Tacho is the alternative to the very very expensive AUDI Digitaltacho, which one cannot insert anyway, without the complete wiring harness for Digitaltachos. The Digitaltacho costs meanwhile 2000 euros with AUDI The Tacho offered here is simply exchanged against the original similar to Tacho. It was converted in such a way, that the original Tachostecker to be further used can do. It must only three vein cable into the engine compartment are put for the digital Tachogeber (pulse generator) the cable can simply by the hole the no more did not need Tachowelle to be put. The pulse generator and the cable do not participate in the auction. One knows the giver of OPELs Digitaltacho take, (it gives favorably with ebay) to these instead of the Tachowelle are screwed on, finished And one is announced already with its AUDI with each meeting. The Tacho fits for all Modele, Facelift, where the Tachowelle has a quick-locking mechanism. Those, which screw a wave to have, can occupy the Tachostecker over, layout are present. Scope of supply: Digitaltacho, all layouts of the Tacho and the plugs Facelift and Vorfacelift. The Tacho looks wesendlich better in the original, can badly be photographed. Lack: Right at the top left in the corner a small tear is in the disk (not visible range) the lateral Mounting plates were replaced with Metalösen, since these had broken out, now again full function. Please read also in my evaluations to this Digiataltacho
Fanns även en analog Turbo variant,
